Hi spent yesterday building a connect calculation was running fine last night and no calculation errors saved project.
Came in this morning project opens ok but every time I press calculate is comes up with Run-time error 53 and shuts connect down!?!
I'm now heading into a meetiung with the clinet and no calculations!?!
Matt
I think the problem here is that you are running V25.
If you located the C:\ProgramData\Bentley\Hevacomp V8i\Hevacomp folder on your computer then that indicates that you do have a V26 installed on your computer as well. Can you run the project in V26 and see if it works ok?
Duncan Brown
Answer Verified By: Duncan Brown
