Where in HWS Netsys can I find the Sizing Criteria. I've seen it once but I got to it by accident and now I cant find it now I need to change some of the pipe velocities.
Ta
Hi Rob,
It sounds like you are looking for the menu below?
If so, this can be found within your System Marker settings. To change this, go to Pipes > System Marker > Change System Marker, and click on the System Marker.
Shane Regan | Principle Building Performance Support Engineer
