I have been asked to clarify that the correction factor cmin been used for calculations with the Hevacomp connect software
Is this true and if so how
Hi AndrewAssuming you are using the latest (V26) software, the changes to cmin are considered. From the 17th edition menu, select Defaults. You can see the adjustment on the bottom left.
regards,
Duncan Brown
