Is it possible to mirror a complete building project in Hevacomp? I have two buildings which are exactly the same as each other but are mirror images of each other. It would save me a lot of time if I could copy one and paste as a mirror image. Thanks in advance.
Hi Steve, there is no function to do so directly in the software, the only suggestion I can think of would be to copy the project, and then change the orientation via the CAD Input defaults, Angle to South setting.
Shane Regan | Principle Building Performance Support Engineer
Hi Shane
Thanks, but that won't work as you would simply be changing the orientation of the building and all elevations. I want to mirror, so that, for instance, the N/S elevations remain N/S but the E elevation becomes W facing and the W elevation becomes E facing.
