CIBSE weather data set
I have just uploaded the full set of .csv files from the CIBSE weather data for all 3 sites within London and I am struggling to apply them within Hevacomp. When I try to use CIBSE data set in the standard menu it is still giving me the error message 'Weather file not found on disc. CIBSE weather data must be purchased before use.' I can browse for the .csv files but do not know which data set to use in order to run a summer design year simulation. I believe the closet weather set to the site I am looking at is London Weather Centre but I do not know weather using future data or existing weather data is the best way to go. Any help anyone could give would be massively appreciated.
Many thanks,
Gareth
Parents Reply
  • Hello Shane,
    I believe that it might be the combined data, however, there are separate files for the future data and the 1976, 1989 and 2003 data sets. I have also followed the final 3 steps and ensured that both index files are loaded. It is a little confusing as to why it isn't working. I can browse for the weather data and make Hevacomp run the simulations for each of the 3 years using the DSY data as advised by CIBSE when running overheating calculations in London using the GLA guidance which can be found here: https://www.cibse.org/getmedia/6a84dc3f-0040-4998-adfd-51ad8c980ba3/Weather-data-FAQs2017Oct.pdf.aspx
    It is a bit frustrating that hevacomp isn't running these automatically but I cannot see any other way to make it work. If you know of anything I might be missing that would be very helpful. Obviously there are many sets of data for each of the 3 London sites. Would that have anything to do with it?
    Many thanks,
    Gareth
