Hi
I am building a Part L model to show compliance with Section 6 of the Building Regs. I have set the building up as a student accommodation which has quite a lot of rooms.
When I run Part L 2013 with all rooms selected the BRUKL report only shows results for the first floor.
My client has also asked me to run the model in Part L 2010. When I run Part L 2010 the software crashes.
Could you take a look at the model or advise a solution?
Kind Regards,
That makes perfect sense, thanks for your help on this.
