I'm currently working on a model and have deleted a room, however, the following message has came up... "room not found in database. To prevent possible database corruption design database will now shut down" and the project is now inaccessible. This is causing a major problem as I have taken the model quite far and now I cant access it. Can this problem be resolved without having to start again?
Kind regards,
Claire Mackenzie
Hi Claire,
Yes I should be able to recover your project for you, if you could please upload the zipped project folder to this link.
Also, please note there is some information on this error in this article.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Can confirm that the project came through fine. I am working on it at the moment and will be in touch as soon as I can resolve the issue.
Thank you for your help
No problem at all Claire, you should receive an email with the repaired project shortly.
Answer Verified By: Shane Regan
