I'm currently working on a model and have deleted a room, however, the following message has came up... "room not found in database. To prevent possible database corruption design database will now shut down" and the project is now inaccessible. This is causing a major problem as I have taken the model quite far and now I cant access it. Can this problem be resolved without having to start again?
Kind regards,
Claire Mackenzie
Great thank you. Just tried to open it and it works fine. Thanks again. Much appreciated.
Happy to have helped!
Duncan Brown
Hi Shane
I have got same issue with my DDB Project. Please Could you be able to help.
Hi Shane and Duncan,
I have this problem when I deleted a room in the program, it continued with this message tried all I can to try and fix but could someone lend a hand on this one?
at my company we Use Bentley frequently for quick calculations, so if there is anyway we could do to solve this in house, would be helpful.
looking forward to your reply,
Jason
