Could you tell me please how to connect a header to 2 pipes heating system please?
Hi Maryna - This document should provide the information you require. Regards,
Duncan Brown
The problem is, the header doesn'r appear on the schematic. Do we need two headers for flow and return? and after connection pipes into the header it doesn't seam real to connect the incomimg pipe to header..
Headers can only be placed on flow. You should draw your flow pipe to the point you wish the header to be. Then draw the header. Then connect your other flow pipes into the header.
I have made a very simple project available for you to examine. You can download it from here.
Thank you! I have downloaded and will try again, I have already spent ages to work out how to do it.
