How to create a file to get the Floors tab available and also to be able to create riser or pipe drop..
Maryna - if you wish to consider heights and floors you should start your project with a DXF file.This information is available in the software manual, which you can access by selecting the Manual option from the File menu.Regards,
Duncan Brown
Answer Verified By: Maryna Drachuk
Duncan,
I have tried to reduce the dxf flie, but the problem is even 500kb is too big for Hevacomp
There is no size limit imposed on a DXF file. If the DXF is very large, it may take longer to draw.Please see this article for an explanation of unit limitation.Regards
Thanks!Sorted!
