Adding NCM Construction Databases (standard library / inference) to Hevacomp Materials & Glazing Database
I have been using other building modelling software that make use of the standard NCM Construction Databases for library / inference.
Are there any plans for the NCM Construction Databases to be added to the Hevacomp Materials & Glazing Database?
  • Hi Shane,
    Thank you for coming back to me.
    It would be hugely time-saving if NCM materials and glazing databases were added to Hevacomp DDB
    I’ve been doing exactly as you’ve recommended, but this adds time having to check the NCM databases first for each construction type.
    I also waste valuable time creating the correct glazing types – The NCM glazing database would be a very welcome addition.
    Brian
Reply
  • Hi Shane,
    Brian
