I have placed a system marker (tank) and now the pressure is not sufficient. If I have to change it to a pressurized system, How do I do it?
Hi NitheshFrom the Pipes menu, select System Marker, then Change System Marker. Then click on the System Marker and make any appropriate changes.Regards,
Duncan Brown
Thanks for the support!
