Hi there,
I have a room where there is surrounding infrastructure/trees etc. I have played around with the "Average elevation angle for surrounding buildings, terrain and cityscape" function and found that increasing the angle will reduce the amount of time there is a solar load on the building, but the peak temp inside the building increases in comparison to an angle of 0. This has been in the Summer function.
Looking to understand why this is?
Tim
Hi Tim - I've done some testing and I am not seeing this. Can you exit the software, zip up your project folder, and use this link to get the project to me? I'd like to test this out. If you can let me know what elevations you have been considering and the results you are experiencing, that would be a great help.Thanks,
Duncan Brown
