Hi
I've been working on DDB and seem to have developed ghost rooms - they appear in the list of rooms but there's nothing on plan or in the 3D view. I've deleted all the rooms in an effort to solve the issue but the ghost room remain. Anybody got any ideas as to how to delete / locate these spaces ?
Cheers
Graham
Hi GrahamI should be able to remove the ghost rooms. Exit the software, zip up your project folder and use this link to get the zip file to me. If you could reply back with a list of ghost room names, that would be a great help.Thanks,
Duncan Brown
Hi Duncan
I've uploaded the files and the ghost rooms are called 1, EEE, Q, W and WW - it seems one of the juniors had a go at fixing the problem hence the room names.
Hi Graham - the ghost rooms are the only rooms in the project. Surely it would be simpler to start the project again?
Check out the roof profile - trust me it's easier to put all the rooms back in than try putting that roof back in.
Ok - I've repaired the project and sent you a PM with a link to pick it up.Regards,
