Rooms which are listed on the global changes list are no longer showing on the floor plan or in the 3D view of the building. Is there a way to reinstate the room as they remain part of the model as they are in global changes list and results are calculated for those spaces.
Hi Duncan
I also have had the same issue with my hevacomp model, could I also send you my model to resolve please ?
Ryan
Hi Ryan - assuming you haven't made too many changes to your model in Room Data mode, the bottom part of this document should help. Ensure you back up your project before attempting the methods described.Regards,
Duncan Brown
Is it possible to send you my model and delete zones in the first floor? I have tried my end and the software doesn't respond and crash. thanks
Hi Ryan - did you get your model back into CAD Input mode and are trying to delete from there?regards,
Hi
Yeah put it into CAD input mode but the software crashed when deleting a room from the first floor.
