Does anyone know what this plenum box is used for in the ductwork? Is this replicating an Air Handling Unit? What is the purpose of this Plenum Box?
Best Regards,
Peji
Hi Peji - the plenum box allows you to connect different types of duct work together - for example, circular and rectangular. It also allows you to define a 4-way (or potentially more) intersection. You should be aware that it has a fairly high k-value of 1.4.Regards,
Duncan Brown
Thank you Duncan, do you may have a picture as an example?
You could try this link.regards,
