I'm trying to input a student accommodation building into Part L - each apartment has a bedroom and ensuite with the overall apartment having a dedicated HRU, the results on the BRUKL document criterion 2 show the ventilation system as being type A and type D when surely the results should be just a type D. I've tried to find an answer but seem to be drawing a blank. Any ideas ?
Hi Duncan
PDF
As requested.
Hi Graham - Sorry about that - I meant can you provide a screen capture of typical room data? Thanks.
Duncan Brown
We seem to be crossing in the post! Can you also provide me with the HVAC tab, so I know how this is being set up? Thanks!
Thanks for that. I just wanted to ensure that I was running the same systems.While the results may appear misleading, the data does actually match both conditions and appears to be working as intended. For example, if you switch off heat recovery you will see A and B selected, as again both conditions are met by the selected system.I've checked the data reflection report to ensure we are passing the correct data into the SBEM calculation, and that's all fine.Regards
