To Whom it may concern
Is there a setting where you can set the amount of heat gain from the equipment thanks for your time
Hi Rodgers,
You can edit the heat gains in your Room Data settings. You can change these settings in CAD Input or Global change.
In CAD Input simply double-click in the relevant room.
Shane Regan | Senior Building Performance Support Engineer
Thanks Shane
Hi Shane
Can a figure of w/m2 be inputted for casual gains rather than watts thanks for your time
You can do so in Global change as mentioned above.
Will do that thanks Shane
