To Whom it may concern
For the results on Cibse Gain I am getting negative values for both sensible and latent , I have tried making the partitions to no heat flow but I am still getting the same negative values can you please help thanks for your time.
Rodgers - negative values indicate that the room is loosing heat - a heat loss. Changing partitions will likely not affect this, and they should maintain the connection to other zones, otherwise it will skew your results. You should be considering your exposed surfaces.Regards,
Duncan Brown
thanks Duncan much appreciated
