To Whom it may concern
For the the results in the Cibse gain I am getting a value of zero for sensible in rooms that have equipment gains and lighting gains as well as occupancy can you please help thanks for your time
These are my inputs for G10 as seen in the above results
Hi Rodgers,
I would suggest clicking on 'Full' in the bottom left of the CIBSE Gain results to view the full breakdown of the gains. That should give you a better idea of what is happening.
The information on heat load types here should also be of assistance.
Shane Regan | Senior Building Performance Support Engineer
