Hi i'm getting this error code and the system keeps crashing. Has anyone had any similar issues?
Run-time error '3019' Operation invalid without a current index
Claire - I can only think of either the project was closed badly - for example, the computer shutting down with the project open in the CAD window or in a calculation - or a bad write back - again, for eg. a network issue, or using external devices (USB stick, cloud space) to store the project on.Regards,
Duncan Brown
The only thing i could possibly put it down to is a network issue,
Thanks Duncan
Sorry we couldn't really help more. Its tricky to proffer a solution to something when we can't really pin down the cause.Regards,
I can imagine. It's just so frustrating when it crashes at the end of the project. No worries though. I appreciate your help
If you can contact us as soon as anything goes wrong, with what went wrong, we will try and assist!
