Can you convert a Design Database project into a System Builder project.
Hi Craig - I'm afraid that's not possible. When a System Builder project is first generated, a number of files are created that are unique to System Builder. The project picker then uses these files to differentiate between Design Database and System Builder projects. As these files don't exist in Design Database, you cannot transfer the project.Regards,
Duncan Brown
