When applying Co-ordinates for External Shading to my Window Surface, is the 'Z' co-ordinate the measurement from 0 to center of window surface?
Hi James - I'm unsure of what you mean? I don't recall a 'z' co-ordinate being asked for?Thanks,
Duncan Brown
Hi Duncan, so I am using Room Data to model my zones along with external shading for surrounding buildings and some brise soleil. When you click on the window within the Room Data Surfaces tab, it asks for 'Co-ordinates for external shading'. I can apply the x and y from my dxf file. Just wondering for whether the Z coordinate is used to apply height to the window, if so would that need to be height to the center of the window?
This is used to defined a center point for the Windows.See this exert from the manual:The manual is usually available in Design Database by pushing the "?" buttons, or from pushing F1 in some areas.Regards,
