No 350Ømm pipe size for Steel BS 1387 Heavy
Hi Richard - The non-manufacturer specific ranges are sourced from CIBSE guides, and I'm having difficulty locating reference information for this size. Are you examining a specific manufacturers range?Regards,
Duncan Brown
I need to have an accurate estimate on the total water volume of the system. The project calls for a 350Ømm pipe headers but the said size is not available on the drop down list for Steel BS 1387 Heavy.
Please, if you have other resources that you use with this type of concern that possibly you can share, it will be very much appreciated.
Highlighted below are 350Ø pipe size from BS 1387 and ASME/ANSI B36.10/19.
PDFPDF
reference:
http://www-eng.lbl.gov/~shuman/NEXT/CURRENT_DESIGN/PV/movesa/PipeSize(B36.10_19).pdf
http://hiapchuan.com.sg/pdf/15.british_standard_welded_steel_pipes.pdf
Hi Richard - My colleague should be contacting you shortly through the service ticket you raised.Regards,
Hi Richard,
You should have received an email containing the custom data as requested - if not please check your Spam folder for emails from support@bentley.com.
Shane Regan | Principle Building Performance Support Engineer
