When analysing my building using CIBSE Gain it only shows latent, sensible and total gains in the results/graph. When using Carrier gain it shows solar etc in far more detail.
Why does the CIBSE not show the solar, fabric etc in the graph - the manual suggests it should.
Craig
Hi Craig,
This happens when you select the option in CIBSE gain to allow temperatures to rise. All sensible loads are put through the appropriate CIBSE equations and cannot be separated out afterwards. You should consult this Wiki for more information on using temperature rise.
RegardsSteve
Steve Brown | Bentley Systems
Answer Verified By: Craig Methven
Stephen many thanks.
