I am modelling the heat gains for the first floor of a building but the ground floor is out of scope.
is there a way to set a fixed tempearature for a third party floor below mine?
Kind Regards,
Hi Grant,
Yes, you can specify the temperature of the adjacent rooms below by using Rooms > Change Surface, and selecting the floor of your room:
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
