Hi i'm trying to set up roofs and keep getting the error code run time '11'. Division by 0.
I got our IT department to install the latest graphic drivers, however the problem is still occurring. It is quite a complex roof drawing. Could this be the problem?
Hi Claire - there shouldn't really be a limit to the roof complexities. I can't really comment further without seeing the project. Set up your roof drawing (if its not already done) and then exist the software entirely. Zip up the project folder and use this link to get it to me. I'll take a look when it arrives.Regards,
Duncan Brown
Hi Claire - Much as I thought, the complicated roof wasn't really the problem, but you did have some areas where roof sections where wholly enveloped by other roof sections in this area:
I've cleaned this up a bit - though it will still need checking - I'll PM you with a link to download the model.regards,Duncan
