I have recently downloaded Service Pack 6.1 for the Connect Electrical Systems Design. However it appears to be still based on the 17th Edition of the Wiring Regulations. When will the 18th Edition Service Pack be available to download?
HI Ken - I'm checking with our dev team - I should have more information shortly. Regards,
Duncan Brown
Further to the above, we are intending to update the software in line with the implementation date of January 2019.Regards,
Thanks for that information Duncan. However the sooner the software reflects the changes the better as the design process for projects due to be on site after January 2019 will be taking place well before the implementation date.
Hi Ken - After reviewing the changes in 18th edition, there will likely only be small changes to the software. Schematics can still be designed in the current version and then switched and recalced when the 18th edition update becomes available.Regards,
