I have a partially conditioned building, I am trying to use the frequency simulator to tell me what percentage of the year the existing FCUs used will not meet the cooling demand and what the resultant temperature will be during this time.
The issue I'm having is that the option to state the FCU cooling Load (kW) is greyed out. so I can not define the existing system.
How do I get the simulator to allow me to fix this information.
David Forster
Hi David - Could you get me a screen shot of the dialog in question? I'm having trouble locating the Cooling Load option?Thanks,
Duncan Brown
Since I posted this I've realized the greyed out box I was referring to is there as a fix for the room requirements, rather than an option to fix the cooling load of the equipment in place.
is it possible to fix output of the FCUs?
Hi DavidNo - its not possible to fix these figures. They are generated during the calculation, and utilised accordingly. If you wish to adjust your HVAC to consider different conditions you should do it through HVAC Systems/Room equipment.regards,
