When running the calculation on connect I keep getting the error message - Supply: cannot find device large enough.
Any suggestions as to what I am doing wrong here?
Hi Mark - The system calculates the required device size, then examines the selected range to pick a suitable device. If there isn't a large enough device in the selected range then you will get this message. For example, the calculation requires a 63A device, but the largest device in the range is 50AYou should select a device type from a different range.Regards,
Duncan Brown
Hi - I've got a 10kVA transformer supply to my section board. Do you know which range I should use on my section board to allow this?
I'm afraid not - the software has hundreds of ranges of devices. This is something that we would expect the engineer to select.Regards,
