Hi There,
I've created a project in Netsys CWS which is a multi level project. I closed the project and when i come to re open it I get the error above. I'm using windows path/ file method, and the project is in a location which isnt protected or write only.
The green tick is available and the window shows a project is there with the correct number of floors etc.
Have I set up the system wrong or am i doing something wrong??
Hi Wayne - I've checked the code and its a fairly simple attribute check. Can you check the project folder itself to see if it is set to read only?
Duncan Brown
Hi Duncan,
I've checked and the folder isn't set to read only, I've set it to read only and un set it to try and i still get the same error message
Many Thanks
Can you move the project to your local hard drive and see if you can access it from there?
The file is on my local hard drive.
Could you try a different location?
