Hi There,
I've created a project in Netsys CWS which is a multi level project. I closed the project and when i come to re open it I get the error above. I'm using windows path/ file method, and the project is in a location which isnt protected or write only.
The green tick is available and the window shows a project is there with the correct number of floors etc.
Have I set up the system wrong or am i doing something wrong??
I've relocated the project to the desktop and still the same issue, I create a new project in the same location and get the same issue can't open it. I create a new project on the desktop and can open the project? Any suggestions? I'm loathed to start a new project which is a 10 storey apartment block to find I cant open it to continue working on it.
Kind Regards
Please see my suggestion above. Try and create the new project in a different location. Don't re-use the existing project folder.Note that you do not need to generate a service ticket AND a forum post. Both are monitored carefully.
Duncan Brown
Hi Duncan,
I've set up the project as a new one and deleted the original project data, I've located the new project on the desktop, which isn't ideal but gets me moving on my project.
Thank you for your help, I may return to this when i have more time, but for now have to get this project underway.
Where did you create the original project? What was the path?
This is the path of the project: -
C:\Users\Wayne\Google Drive\2 ***************\Projects\J0115_Hollycroft_Kirkstall Rd\3 Drawings\Hevacomp Files
