Hi There,
I've created a project in Netsys CWS which is a multi level project. I closed the project and when i come to re open it I get the error above. I'm using windows path/ file method, and the project is in a location which isnt protected or write only.
The green tick is available and the window shows a project is there with the correct number of floors etc.
Have I set up the system wrong or am i doing something wrong??
Also - is it just this project? Or does it happen with other projects?
Duncan Brown
I've copied the project to the desktop and still get the same issue. This is the first project I've set up, however I can open the project which I set up on the design database while going through the training pdf.
Many Thanks
Is there a way of opening a project without going through the main menu?
Can you try moving the project to another location?There is no way of opening projects without going through the menu.
Ah. I see you tried a new location.Can you try the following?Create a new projectExit the softwareGo back into the software and see if you can load the new projectExit the softwareIf you are able to load the new project then copy the files from the original project into the new project, overwriting where askedSee if you can now open the new project
