Hi There,
I've created a project in Netsys CWS which is a multi level project. I closed the project and when i come to re open it I get the error above. I'm using windows path/ file method, and the project is in a location which isnt protected or write only.
The green tick is available and the window shows a project is there with the correct number of floors etc.
Have I set up the system wrong or am i doing something wrong??
We really don't recommend saving things to virtual drive spaces. There can be issues with synchronising, and that could treat your project as being read only. If you intend to generate projects on your own hard drive I would recommend creating a Projects folder in the root of your C or D drive, and using that.regards,
Duncan Brown
It isn't in a virtual drive, its a physical drive on my c: which just happens to be called Google drive and gets backed up to the cloud.
As i said for now i'll keep it on my desktop.
Kind Regards
Wayne
