I am having difficulties auto defining rooms the design database.
After following the tutorial video, I have set up the layers on the dxf as walls, partitions, doors and glazing as instructed. The layers are highlighted as you would expect them to be. However when I attempt to autodefine a room, all I get is the above message.
I understand that the most common reason for seeing this error message is that there is a gap somewhen in the space you are trying to autodefine, so I selected a room that was partition walls only and even removed the door for good measure, then polylined the inside wall line, tracing the existing dxf. After checking it was sealed, I ran the autodefine again and still got the same message.
Are there any other reasons why this message should be displayed? I am struggling to understand why a room made of only 4 walls could be too complex to define?
Thanks in advance
Duncan
Thank you very much, it is working now.
Best Regards
Jon Olise
Great. Thanks for letting us know.Regards,
Duncan Brown
