Good morning, I modelized a room with a glazing of 0.6 W/m2.K and I want to get a G value (BS 410) of 0.24 and a U value (BS 410) of 0.62.Could you please advise a way to reach it ?
Hi Benjamin - is this for use with Design Database calculations or Design Simulation calculations?Regards,
Duncan Brown
Good afternoon,
Its for a Design Database calculations
The U and G values, along with the glazing fabric details are used by Design Simulation and not Design Database. For glazing data for Design Database, you should consider the Glazing Properties section. You can fix these to whatever you desire. The SHGC value is more-or-less equivalent to G values. You should define all of the parameters in Glazing Properties.This document contains more information.Regards,
