Run Time Error 75 using design database
HI
I was in design database and was loading in a CAD input to work on. I selected a dxf file, set the floor height, name and orientation. and when I clicked the green tick to load in the dxf a run time error popped up " Run-time error '75': path/file access error. I also get the same error when I click on room data can you please help
Cheers Alex
