How do you put CHP into an SBEM & EPC?
Hello Stuart - CHP is only available on a limited number of HVAC systems. If you select one that allows CHP, an option to include CHP will appear. If you select this option you will be able to enter your system on the CHP, District heating and Air conditioning tab on the 'General' page.
Duncan Brown
Answer Verified By: Stuart Tattersall
Hi Duncan,
Is there a step-by-step guide of how to put a CHP system in to provide domestic hot water only to the building?
Stuart
Hi Stuart - CHP cannot be used to solely provide for hot water systems.Please see this document.Regards,
