Hi I am working from external server and can't access to any hevacomp files on the server. got 75 error. it works fine when working form my desktop. can't access to any of the files located on the server even from my laptop.
Hi Joanna - I'm not sure I understand the issue? Do you get an error 75 when you open a project? Are you able to navigate to your project folder but then get an error 75 when you open the project?regards,
Duncan Brown
When trying to create new. got other issue when trying to open one project but it seems to work fine on other when opening but can't create new one atm
Is this a new installation of the software?
No not at all.
What kind of project are you trying to open? Is this program specific?
