I've been trying to run a temperature frequency simulation for an 8 room building.
ive set everything up (repeatedly) and left the simulation to run for several hours / overnight several times.
The simulation makes never seems to finish. the calculation needs to be completed and sent out ASAP
What reasons can there be for a simulation getting stuck and providing no error codes and what can I do to make it work?
Kind Regards
David
Hi David,
I would suspect the path is too long, as detailed here.
Please copy the project folder to your C drive and try again.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Answer Verified By: David Forster
Thanks Shane, that worked perfectly.
