Air Change rates
In the CAD input within thermal design within the a/c rate this is where we are inputting the infiltration rate of the building.
When it comes to the heatloss section where we are selecting the fixed air supply temperature and then inputting the air change rate here it does this globally. Is there a way to do this individually for each room as the air change rates are not the same for all rooms?
George
