I have number of issues with he package
! Have a ductwork system where the duct work changes from 400x400 to 400 x 200. I fixed the ductwork to the duct indicated but the results only show it up as all the same size. furthermore the labels added shows it as the wrong size, even though it is fixed. Any thoughts.
Also, when changing heights in the room, it appears impossible to fix the vertical piece of duct between the 2 levels as it cannot be selected to fix
Hi IanWith regards fixing duct sections, please see the discussion here. With regards fixing vertical sections, please see this document.Regards,
Duncan Brown
Both now works. Thanks
Just one more thing. Is there an easier way of changing the working level, or do you have to select draw duct and right click every time? I cant see a pull down to do this?
There isn't a pull down for changing level. You can either right click, or set your level in Ducts/Defaults.regards,
