Hi could someone advise whether there is an issue with the files when running PartL for SBEM. The exact same model run for English and Scottish Regs appear to be the wrong way around as the the Scottish Section 6 Regs require a larger carbon reduction compared to the English part L2 regs. However, the TER for England is significantly smaller compared to the TER for Scotland.
PDF
Thank you again for your time and input.
No problem Claire, have a nice weekend.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
You too thanks
