Hi i wonder if anyone has any suggestions,
I'm currently sizing hot water F&R for a 3 story building, However 1 pipe is massively over sized. Its happening on section 19 return pipework between floors. I've tried changing the draw pipe heights and right clicking on the pipe using fix/unfix etc but cant seem to pinpoint the pipe to change it.
Could you provide a link so that I can upload my model for checking?
Hi Claire - it could be possible that you have more than one pipe section in the riser. It may be better to delete it and redraw, or use the group select.regards,
Duncan Brown
Thanks i'll give that a try Duncan
