Hi there,
Is anybody knows how to find lost data of dxf?
I traced the floor roof etc. all done and a new user who doesn't know how to use hevacomp create a second dxf file on his computer and start tracing and all of my job gone. Nothing remains dxf pan is empty. Any idea?
When you select a DXF file for a Design Database project, a new file is created in the project folder with a DXF.CACHE extension - for example, your DXF file is called FLOOR1.DXF, then FLOOR1.DXF.CACHE is generated in the project folder, and it contains the polyline information that the program uses. It shouldn't matter if the DXF is moved, as the program will read the DXF.CACHE.Regards,
Duncan Brown
