Hi there,
Can you please advise how to change the floor level?
Hi Nek,
You would need to copy the floor to do so - please find the relevant workflow here.
Shane Regan | Principle Building Performance Support Engineer
Can you please tell me how to change the floor name?
It is not possible to directly change the name of an existing floor. To do so you will need to use a similar workflow as at link above.
ok i got it thanks
