Goodmorning,
I cannot see the roof for one room on the top floor. This causing a problem i cannot trace the roof and fill up the vertical gaps.
Can you please advice?
ThanksDOCX
its ok i sort it with different way just add the missing room and trace every section of the roof by insert the same dxf file and do it one by one section.
I would like to suggest the software need to be updated, please. If you need suggestions just tell me.
Answer Verified By: Nektarios (Nek) Ktorides
