How do I fix a bend type on the top of a vertical rising duct and the bottom on the same floor. If I fix using fix bend/Tee command It will only let me fix one. Do I have to try and simulate this in a different way to get the outcome.
Isometric view example
Fixing view example
Hi Dan, I see what you mean. It looks like these two options are the only methods that would give you what you need. Adding the additional floor (while inconvenient I'm sure) is a good idea to get around this if you have a very large system. Alternatively it might be easier to just add a slight slope to the riser, so the bends are not on top of one another. This should let you select each bend while still giving accurate pressure results.
Shane Regan | Principle Building Performance Support Engineer
Answer Verified By: Dan Frost
krogerfeedback Great article. Very well explained. Thanks for the share.
