I am trying to model an atrium space which allows for the solar gain from some roof north lights.
I require the below clarifications for the correct modelling of the roof lights:
You should not need to specify such Rooflight data - once your roof sections have been drawn simply select Add Rooflight and trace it. The Rooflight will automatically take the height and pitch of the roof section it is added to. Please see section of manual as below:
Shane Regan | Principle Building Performance Support Engineer
