Is there a way to print of the discrimination report? I have found it in the reports section but the option to click OK is greyed out. My client needs a print out of the earth fault and overload graphs which I can do to PDF.
The discrimination check tool is purely graphical, however you will be able to customise your reports if you wish to display these results. To do so, go to 18th edition > Reports Designer, and set up the data required.
Once a custom report has been created, it will be shown as a report type in the Reports viewer and may be selected and used in exactly the same way as any standard report. For further guidance on setting up such reports see section 5.1 of the Connect manuals.
Shane Regan | Principle Building Performance Support Engineer
Shane
Yes I understand I can produce a report that says PASS but it would have been nice to PDF the view on the screen like you can with the Earth and Overload graphs as it shows the fault currents used in the calculation. I have used the Snipping tool to produce a screen shot. My client has a technical department and they like to see all of the parameters used in the calculations.
